how many miles on your ram??
Old Jun 11, 2009 | 05:45 PM
  #41
Gone Fishin's Avatar
Gone Fishin
2005 2500, 104K+----axle seals, driveline seals, rear u-joints w/ fronts soon.
Everything else still running great, and yes I do use all of the 345 hp occasionally.
Old Jun 11, 2009 | 08:12 PM
  #42
santafehemi's Avatar
santafehemi
2007 1500 with 20,318 with no major issues. just a squeak that sounds like it comes from the front of the engine when i turn the engine off. already took it to the dealer and they couldn't figure out what the problem is
Old Jun 11, 2009 | 08:44 PM
  #43
blueworkfish's Avatar
blueworkfish
58k on my 02 and just had to change my front axle seal
Old Jun 11, 2009 | 08:50 PM
  #44
Ilovemytruck's Avatar
Ilovemytruck
2004, 4.7L with 69,128 miles.
Whats considered major repairs lol?
New water pump, radiator x 2, ABS control module, Idle air control valve, ABS wheel speed sensor x 2, new radio and new tweeters because they blew, all new hoses all of them seem to developed pinhole sized leaks, new serpentine belt, new thermostat, new rack and pinion and she is starting to burn oil so I am thinking maybe new headgaskets will fix that. I baby her untill she reaches the open interstate or highway then I open her up.
I used to change the oil every 3k along with the air filter. Changed tranny fluid and filter change every 30k. I also changed rear diff fluid twice. Thank goodness I havent had the dreaded rear diff blow up. The 1k I paid for the extended warranty saved me about 3k in parts and labor.
Old Jun 11, 2009 | 10:00 PM
  #45
1LowRam's Avatar
1LowRam
02 4.7 64k
Old Jun 11, 2009 | 10:58 PM
  #46
dodge it then ram it's Avatar
03 with 150,000 plus miles. Changed out rack and pinion once. About it. Cost freakin' $850.
Old Jun 12, 2009 | 11:43 PM
  #47
Kamel87's Avatar
Kamel87
i got an 03 4.7L with 110k on it and so far so good
Old Jun 13, 2009 | 12:14 AM
  #48
Denniss66's Avatar
Denniss66
2003 dodge ram 1500 qc hemi. i have 190000km on it i have put in a new front diff at about 90000km not covered cause of different size tires. i had 2 powersteering pumps go in a week. my intake blew up into pieces at 117000km and they didn't cover it cause it was 2000km over warrenty. had a transfer case blow up as well all cause i didn't change a bad u joint, and now i got to change the transfercase position switch. other than that truck is still awesome.
Old Jun 13, 2009 | 12:16 AM
  #49
Ram4wd's Avatar
Ram4wd
Smile how many miles on your ram??
2006 1500 4x4: 33,250 miles. Bought used two years ago with about 11,000 on it. Major repairs: Front Axle Actuator (4x4) and blown right front shock - both replaced under warranty.
Oil changes every 3,000 miles (straight Dino!). Have changed front and rear Diff's plus Transfer Case twice; most recently at 30,000 miles. Also flushed Transmission at 30,000.
Since adding K&N CAI, Flowmaster and 3" exhaust and tuner, yea I tend to get on it a little. Hey, at age 58 - I grew up in the muscle car era. Hell my first car was a 1974 360 'Cuda complete with the pistol grip shifter! (sure wish I still had that baby!!)
I don't beat my truck, I couldn't afford the repairs for one thing. However, I was stuck in the snow about a month ago up behind Mt Hood, for about 3-1/2 hours and I generated a lot of smoke from the rear end trying to get out of there. I have the factory LSD and no issues, so far even from that little episode. Once I calmed down, aired the tires down a little more, she walked (backwards of course) right out of the mess and I was on my way.
Old Jun 13, 2009 | 11:29 AM
  #50
casper3380's Avatar
casper3380
07 Ram Quad Cab. 17500. had her two years this month(6/30). Running royal purple in the motor will upgrade rest when the time comes. Had front shocks replaced under warranty, replaced when they started to leak-never felt any issue. New tires next year. Full sound system replacement. Maybe a shell too. oh and until i get an after market exhaust, a drop in k&n.
