sensor location on 06 RAM 5.7
Old Jun 16, 2009 | 08:16 PM
Dieselmonkey's Avatar
Dieselmonkey
Default sensor location on 06 RAM 5.7
Hello all, can anyone tell me where the TPS and PCV are located on 2006 RAM hemi? thanks
Old Jun 16, 2009 | 08:23 PM
dirtydog's Avatar
dirtydog
Moderate User
TPS is mounted on the throttle body at the butterfly needle. 2 screws/bolts usually
PCV is on the valve cover and has a 1/2" or so sized tube attached to it. pulls off, presses on
Old Jun 16, 2009 | 08:29 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
PCV is to the left of the throttle body about 4 inches and screws into the intake manifold. Far as I know the hemi's throttle body doesn't use a TPS....at least not a conventional one.
Old Jun 16, 2009 | 08:34 PM
Dieselmonkey
Thanks, can I just replace the tps by itself? can you tell me what the black locking (turns 90 degrees) dial to the left of the throttle body is?
Old Jun 16, 2009 | 08:37 PM
SeVeReDiStOrTiOn
Already did..it's the PCV
Old Jun 16, 2009 | 08:50 PM
Dieselmonkey
got it, it seems the tps is built into the tb as a unit, kinda sucks you cant just replace the sensor.
Old Jun 16, 2009 | 10:21 PM
butch1581's Avatar
butch1581
Looks like that PCV Valve is a dealer only item huh? When should that be replaced? When it fails? thanks
