Old Aug 10, 2015, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
A/C troubleshooting
Old Jun 20, 2009 | 07:36 PM
nim81's Avatar
nim81
also make sure your a.c. compressor is running when you are checking the pressure....and when filling !
Old Jul 3, 2011 | 07:42 AM
fullarmor613's Avatar
fullarmor613
I have the same issue with my 03, I have changed the fan relay and the fan assembly, I have power to the relay and the fuse box I have replaced the fuse also. on occasion the fan will turn very slow not fast enough to do any good,
Any thoughts
Old Jul 3, 2011 | 08:18 AM
dirtydog's Avatar
dirtydog
Moderate User
Any thoughts
This thread goes back a bit so let me see if I can help you.
ANYTIME you have warm air blowing at idle and cold when moving means your condensor is clogged.
As for not having full High on your fan settings. I think you need a new control panel. That 3 button heat/ac control panel under the radio. High all the time means a variable resistor went bad. Only Low, means the control switch unit is the problem. Rarely ever is it something else.
Old Jul 3, 2011 | 01:28 PM
fullarmor613
It does not run on a low setting it ran about 1/4 speed for maybe 10 seconds after I changed the fan and the relay.
Old Jul 3, 2011 | 01:32 PM
dirtydog's Avatar
dirtydog
Moderate User
There's a variable resistor that RESTRICTS speed. When this goes bad, you only have high speed. If you can't get medium, med-high or high,(meaning only low works) then your control switch is likely bad. I'd be very surprised if the variable resistor failed in a low operation only. Generally that would mean water damage.
Sounds like maybe a pinched wire somewhere's. Just because you have power at the relay doesn't mean it's getting to the fan. You can have 12v reading on a 32guage wire, heck, even a 1,000guage wire but you certainly can't run 20A+ of current through that thin wire to turn the blower fan. A pinched wire can restrict current which in turn restricts the speed output. The wire can get very hot and the connections tend to arch. This is why components fail even when not recieving enough power.
You can test the fan output with a dummy light. Most import dome light bulbs draw loads of current. Take the highest rated 12v bulb and use the blower wire to light it up. If it fails to light or appears dim, then you have a pinched wire.
Old Jul 15, 2014 | 12:17 PM
gsorge's Avatar
gsorge
Default Other A/C issue
I know my condenser fan isn't working and I was getting cold air when moving then warm air when stopped. But just recently, I stopped getting cold air completely and a strange smell comes out of the vents when I try the A/C. I had the compressor checked along with getting the Freon charged and was told that isn't the problem. However, the shop wasn't able to pinpoint what was wrong. I'd like to know what may be causing this before investing in the new condenser fan and would appreciate any help I can get. Thank you!
Old Jul 15, 2014 | 12:59 PM
cd36c's Avatar
cd36c
I don't know what is involved in a compressor check, but do you know if the compressor is coming on and it isn't cooling, or is it not coming on at all? Also, have you replaced your condenser fan? It will be tough to troubleshoot if that isn't working.
Old Jul 15, 2014 | 01:55 PM
gsorge's Avatar
gsorge
I haven't replaced the condenser fan yet. The A/C was blowing cold when the truck was moving but now isn't. According to the place that charged my A/C, my compressor is kicking on and off and they didn't think that was the problem. It was at closing time, but they still looked for other reasons for no cold air and didn't figure it out. There is also the smell that developed at the same time the A/C stopped blowing cold air.
Old Jul 15, 2014 | 02:19 PM
cd36c's Avatar
cd36c
Can you feel the line going to the evaporator under the hood get cold when the compressor kicks on? Good luck on checking it with the vehicle moving though.
Old Jul 21, 2014 | 12:35 PM
km04's Avatar
km04
2005 ram 3500 a/c fan stopped blowing. Removed blower checked with aux 12 volts ran fine. Checked power at plug 11.9 volts with ignition on and rheostat set at high 12.23 volts. Removed ignition start switch no corrosion or burnt wiring. Still not working. Any help would be greatly appreciated.
