Which 180 thermostat should i get?
Old Jun 22, 2009 | 03:07 AM
bigmiah22's Avatar
bigmiah22
Default Which 180 thermostat should i get?
I was wondering what 180 thermostat would be best for my 03 ram, i have longtubes on my truck and heard this is a great thing to do to unlean the fuel ratio out. I've been looking at a Jet and a stant...any heads up on either or any others i should be looking at? Also, for those who bought them, how much did you pay?
Old Jun 22, 2009 | 10:10 AM
HammerZ71's Avatar
HammerZ71
you heard right, I was running a bit lean with the long tubes in combination with the SC performance tune (which really advances timing - causing the A/F to be even leaner), instead of having to go to the expense of a custom tune or A/F Piggyback, the $30 cooler thermostat richened me up almost right at stock specs.
Many use the cheaper Stant and they work fine. I chose the more expensive Jet because it's stainless steel and has a lifetime warranty.
Old Jun 22, 2009 | 10:38 AM
dirtydog's Avatar
dirtydog
Moderate User
Go with the better T-stat. As hammer said, it's stainless not to mention that they usually have a stiffer spring rate so they open fast and consistent every time even with high flow waterpumps.
Hammer, did you do any datalogging to confirm all of this?
Old Jun 22, 2009 | 11:42 AM
bigmiah22's Avatar
bigmiah22
http://www.eautoworks.com/product-Je...-RAM_TRUCK.htm
These both say they work for an 03 dodge ram...any ideas?? obviously i'd like to pay less if its the same thing...
Old Jun 22, 2009 | 11:44 AM
nim81's Avatar
nim81
i got my 180* for like 8 bucks at autozone, been on there since nov. 08' works great!
Old Jun 22, 2009 | 11:46 AM
bigmiah22's Avatar
bigmiah22
nvm i think the cheaper one is for the 5.9L ram
Old Jun 22, 2009 | 11:47 AM
bigmiah22's Avatar
bigmiah22
Just called them, they can only get a 203* one
Old Jun 22, 2009 | 11:59 AM
nim81's Avatar
nim81
how lame is that. autozone has really gone down hill lately.
i called them a couple weeks ago for a radiator for a jeep. the local autozone told me there was no way to even order one if they made them at all, so i called the autozone 18 miles away and they had 4 in stock! really i mean they are slacking hard!!
you might try www.rockauto.com
Old Jun 22, 2009 | 12:04 PM
bigmiah22's Avatar
bigmiah22
For those of you who have done it, is Model: Jet Thermostat 10183 the correct one for my truck?
Old Jun 22, 2009 | 12:23 PM
bigmiah22's Avatar
bigmiah22
Just ordered the Jet180*
