03 dodge ram spark plug wires
Old Jun 22, 2009 | 10:52 PM
bigmiah22's Avatar
bigmiah22
Default 03 dodge ram spark plug wires
Can someone explain to me or does anyone have pictures on how the spark plugs wiring system works on the 5.7 hemi? If i buy new wires for it, do they connect to a distributor or do they connect to the coil pack? Is it just the offspark wire that i'm replacing since the coilpack is the main spark in the cylinder? Theres a wire that comes off the coil pack, is that the one thats ran to the other plug for the second fire in the cylinder or am i completely off? ANy help would be great
Old Jun 23, 2009 | 01:04 AM
OlDirtyJohn's Avatar
OlDirtyJohn
i think it may be the same as my 04, so i believe that the plug wires go from the coil pack on top of one plug to another plug. stock, they go from a coil pack on one side of the engine to another plug on the other side. i got myself a set of shorty wires, that connect the coil pack to the other plug right next to it. cleans up the bay a little and is less of a hassle routing them, and trying to figure out if they are hooked up correctly.
Old Jun 23, 2009 | 01:06 AM
bigmiah22's Avatar
bigmiah22
Anyone know where i can find the correct routing for them?
Old Jun 25, 2009 | 06:49 PM
HemiLonestar's Avatar
HemiLonestar
In the Factory Service Manual, which I just happen to have...
Old Jun 25, 2009 | 09:53 PM
Denniss66's Avatar
Denniss66
have you takin the intake cover off your truck cause you can see everything once thats off. i know you don't want to take it in to get the wires and plugs changed because thats expensive. since you asked about the wires for the second spark plugs per cylinder do those wires ever have to be changed cause i know they aren't spark plug wires.
Old Jun 25, 2009 | 11:54 PM
HemiLonestar
They are spark plug wires, just not for igniting the power stroke, the waste spark setup was for emissions. It made it a whole 3 model years (2003-2005) before being replaced with the 6.1 coil pack setup. Must not have been that effective if they decided to do away with so quickly. I just replaced the whole mess with Taylor shorty wires (converting to the other coil setup is pricey) and was done with it.
Old Jun 26, 2009 | 01:40 AM
bigmiah22's Avatar
bigmiah22
I'm going to do everything tomorrow and i'll be removing the intake cover and cleaning up everything. Thanks for the diagram of how the wires go, and yay for the 3rd time of doing my plugs, i went to murrays today and picked up 16 copper plugs and i'm taking out my platinums
