Windshield Wipers
Old Jun 23, 2009 | 03:33 PM
04Phantom's Avatar
04Phantom
Default Windshield Wipers
Hi, I'm new to the forum and i have an 04 Dodge 1500 hemi 2wd, and there's a problem with my Windshield wiper switch i believe, when i turn them over to the first click, they don't work, i have to pretty much turn them on the highest setting to just get them to work, what do you guys believe could be wrong with them? I would appreciate any help.
Old Jun 23, 2009 | 05:52 PM
explorer9950's Avatar
explorer9950
you have a bad multi-function lever, if your truck is under warrenty your dealership can fix that in about an hour, I have the same problem with my last truck and that was the problem, so just tell them you need a new multi-function lever...
Old Jun 23, 2009 | 05:54 PM
Gone Fishin's Avatar
Gone Fishin
The first thing to try is to switch out the 2 relays in the Power Distribution Box under the hood. The relays in there are all the same, you'll have to look at the layout print on the cover of the box to find out which two you have to change out with any of the others. There also has been some mention here on the forum of wires in the steering column getting pinched and cut/ or burned. Try the relays first then take it from there
Old Jun 23, 2009 | 06:54 PM
ramhunter9's Avatar
ramhunter9
i wonder how many people join and post once then never return id say 7 out of 10 post once then leave
Old Jun 23, 2009 | 07:20 PM
04Phantom's Avatar
04Phantom
Alright thanks man i appreciate it, ill check the two relays first, but now that i think of it i had a radio put in at best buy and i wonder if they pinched any wires, but i appreciate the help ill check it out
Old Jun 23, 2009 | 07:22 PM
04Phantom's Avatar
04Phantom
& I'll also check that out, my warranty has ran out on the truck but if i need to ill buy one. i appreciate it
