torsion bar question
Old Jun 26, 2009 | 12:10 PM
MontanaRAM's Avatar
MontanaRAM
Default torsion bar question
how high can you crank the torsion bars when you have 4 wheel drive? i know you can't crank as high as 2 wheels but i'm definitely jacking mine as far as i can safely.
Old Jun 26, 2009 | 12:15 PM
SMKNRAM's Avatar
SMKNRAM
Anything over 2-1/2" gets dicey with your CV angles. Especially they way you run your truck, lol! just start cranking and keep an eye on your CV'S and use your own judgment there Bo Duke!!!
Old Jun 26, 2009 | 12:22 PM
MontanaRAM's Avatar
MontanaRAM
hahaha, do you think 2 inch will be ok on my cv's? i don't need a wheel falling off when i'm bulldogging dirt roads
also, for it to be leveled, it's about 2 inches right?
Old Jun 26, 2009 | 01:58 PM
SMKNRAM's Avatar
SMKNRAM
LOL thats right 2 - 2-1/2" will get it level I am running about 2-3/4 and it is not bad on mine with replacement keys. I have had it in some tough spots since the lift and not had any problems with it. My CVS still look fine
Old Jun 26, 2009 | 02:25 PM
MontanaRAM's Avatar
MontanaRAM
what are the keys exactly? do i need them or can i just crank it up?
Old Jun 26, 2009 | 02:31 PM
SMKNRAM's Avatar
SMKNRAM
you can just crank it from what I understand after I replaced my keys. The keys are what the bars are mounted in on the back end. There is an adjustment bolt that you crank, that pushes on the key and applies added torque to the bar. I have been told that the replacement keys are better quality metal, but dont know if it makes a difference. There are alot of guys running factory keys cranked with no problem. There is a write up in FAQ
Old Jun 26, 2009 | 02:38 PM
MontanaRAM's Avatar
MontanaRAM
yeah, i read the writeup, not much to it though. well, i wish i had known i had the torsion bars before i got my alignment 2 weeks ago. guess i will wait until i screw it up again and then jack my front end to the sky!
Old Jun 26, 2009 | 02:44 PM
SMKNRAM's Avatar
SMKNRAM
You go BO!!! You will need the alignment, but it wont take you long to need another one will it??
Old Jun 26, 2009 | 02:45 PM
jonnymagnum's Avatar
jonnymagnum
I did 5 turns on my T bar bolts and got just over 2" I wouldnt do too much more then that. and IMO cranking them is the exact same as buying new ones, and this way costs you nothing. and if you ever wanna lower it back down. you just crank them down again.
Old Jun 26, 2009 | 02:47 PM
SMKNRAM's Avatar
SMKNRAM
yeah I am with you Jonny! I wish I would have known b4 I spent the money! I still had to crank them to get the lift I wanted
