installed air horn and compressor
Old Jun 27, 2009 | 05:48 PM
kx250frider617's Avatar
kx250frider617
Default installed air horn and compressor
heres my wolo dual trumpet horn with compressor and tank. The cool thin is that i can air up tires and airbags with the fittings it cam with.
The compressor installed un the truck by the back door.
The tank next to the compressor
the switch that turns the compressor on and off. Not to power the horn though. The horn uses the factory button on the steering wheel.
The electronic vavle that is connected to the factory horn button. The hose is 1/4 fittings and is the ones used for airbag systems etc.
The dual trumpet horns. They also have a small tank.
Old Jun 27, 2009 | 06:49 PM
ramhunter9's Avatar
ramhunter9
awesome now we need a sound pic and price and where you got them
Old Jun 27, 2009 | 08:02 PM
gmb4fords's Avatar
gmb4fords
ditto on the price adn where>???
Old Jun 27, 2009 | 08:05 PM
kx250frider617
I got the goods off jcwhitney.com. They arnt cheap however i got the horns as a gift but there around $130. the valve is $30 and the air tank and compressor is $200. All the hardware like wiring and switches and such are around $30 so it was about $400 total. but these babies are LOUD.
Old Jun 27, 2009 | 08:31 PM
mmstar23's Avatar
mmstar23
how much PSI is your compressor putting out?
getting ready to install a seige engineering kit in my dodge and f 350 in a few weeks and dont know if 120 PSI will be enough or if i need 200
Old Jun 27, 2009 | 08:53 PM
kx250frider617
I have 110psi. any more its over kill. once you get to 100psi its all about hoe much air now not neccessarliy the pressure. if you know what im trying to say. Are you going to be running the triple trumpets?
Old Jun 27, 2009 | 09:41 PM
beez's Avatar
beez
Very cool man!! I always wanted to do one of those but its a lot of money for a horn. At least you can run lines and inflate your tires if you get a flat or want to lower/raise tire pressure while you are out.
Old Jun 27, 2009 | 09:54 PM
Ridinhigh's Avatar
Ridinhigh
I have found some on styling trucks for 100 bucks with every thing but the one i am looking at is a 100 for compressor and air tank plus a 100 for dual trumpet horns and it is rated to about 147db so i think that will be loud enough for about 220 total
Old Jun 27, 2009 | 10:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Isnt 1/4 fittings small? What diameter hose are you using? Look good all the same though
MMStar. I have a setup from Seige Engineering and mine is 200psi. Definately get the bigger kit incase you want to do anything else with it later on.
Old Jun 27, 2009 | 10:30 PM
mbaseball3's Avatar
mbaseball3
guys check out hornblasters dot com. and find em on youtube. if you got the dough, those seem to be legit. loud as hell.
