SQUEAKING is driving me nuts
Old Jun 28, 2009 | 08:13 PM
djmaincheese's Avatar
djmaincheese
Default SQUEAKING is driving me nuts
I have an 03 2wd Ram 1500
My Front Suspension is squeaking so bad I dont even want to drive the Truck anymore. I have greased up every joint I could find but its not getting any better. Do they sell polyurethane bushing kits, or is there something else you reccommend I try first. Could it just be that my shocks are SHOT???
Thank you for your help
Old Jun 28, 2009 | 08:59 PM
all of 75's Avatar
all of 75
regarding the poly kit. I did a quick search and I didn't find anything. You should try replacing the shock and see if that helps. They may just be shot. or I could be completely wrong. LOL
Old Jun 28, 2009 | 09:35 PM
mbaseball3's Avatar
mbaseball3
I got crackle like squeaking when I did the rough country level kit. im thinking its just the arms and tie rods being worn. you might check that area too. time to replace?
Old Jun 28, 2009 | 09:59 PM
RedTruck-VA's Avatar
RedTruck-VA
Squirt everything that looks like it might be a problem with some WD40 and if it still squeaks look at the ball joints. My guess is it's ball joints.
good luck..
Old Jun 28, 2009 | 10:14 PM
OlDirtyJohn's Avatar
OlDirtyJohn
ball joints will knock more than they will squeak if they are going out. i was searching for a poly kit for my front end and never really found one. although, you can get just about every part seperatly from rockauto.com
Old Jun 29, 2009 | 09:51 PM
reindeerman's Avatar
reindeerman
I had the squeak from hell. It sounded like old bed springs. I found slack in the driver’s side lower ball joint. I then greased it with a needle injection. The noise went away. I still need to replace it. It did “knock” prior to the squeak. With no grease fitting on suspension joints people are seeing failures before their time.
