Fog light help...
Old Jul 2, 2009 | 02:27 AM
bigmiah22's Avatar
bigmiah22
Unhappy Fog light help...
So i've gone through 4 bulbs and i have replaced the connection to my drivers side fog light and now another bulb has burned out. I want to replace the ENTIRE connections, from the bulb to wherever it goes...Does anyone know where i can find the part for it or what its even called? Any help will be appreciated.
Old Jul 2, 2009 | 06:19 AM
SPARTANENGINEER1701's Avatar
SPARTANENGINEER1701
1 .is the bulbs the proper ones for ur applacation
2 check voltage on plug
3look for loose or cracked connection
4 are they to high a wattage, that would generate lots of heat and blowem
they have lesser resistance and more amps=power=heat energy
5 is the housing loose ,aka jarring the housing will blow a light thats hot.
6 put DC clapon meter to check amp draw then figure power watt
E X I=P E/I=R E=VOLTS I = AMPS R= RESISTANCE P= POWER
TRY IT see if that helps any
