need help
Old Jul 12, 2009 | 08:38 PM
raiderjake78's Avatar
raiderjake78
Default need help
I have an 06 dodge ram 1500 V-8. My truck has just started dieing on me with out any warning, as if someone pulled the plug. I keep good maintenance on the truck. It will die with no indication, no sputtering, all the gauges are reading normal, when it dies, I will start it right back up and its fine, it just does this at will, no specific time. Any thoughts? any one else experiencing this ? it has 60k miles on it, I am the original owner, the engine is the smaller v-8 I believe a 318?
Old Jul 12, 2009 | 08:44 PM
BadHab1t's Avatar
BadHab1t
if im correct the smaller is the 4.7 l thats what i have anyway which in all acuality is a 287cc engine when was the last time it had a tune up ? plugs ? air filter? fluids changed? try cleaning your throttle body at all? these just some ideas it could also be a tps gone bad? these are just things to consider more info would be great im sure some of the other gearheads in here will ask other ?'s good luck were here to help.....
Old Jul 12, 2009 | 08:51 PM
raiderjake78
new plugs at 45k. bosch plugs. K&N airfilter, and changed the Differential last month. only thing left I have not changed is the transmission. I will look at the throttle body, Thanks.
Old Jul 12, 2009 | 09:11 PM
Shea85's Avatar
Shea85
Not long after I got my truck it would die on me once in awhile. After about the third time I took it in. They replaced a bad EGR valve and it hasn't done it since.
Old Jul 12, 2009 | 09:41 PM
HammerZ71's Avatar
HammerZ71
Clean the throttle body, if it's never been done and you've got 45k miles on the truck, it's probably pretty gunked up. EGR is another possibility, but usually to be bad enough to stall the truck, it would be popping a code.
Could also be the actual PCM, but let's hope not, not a cheap part...
Old Jul 12, 2009 | 10:43 PM
Pyro's Avatar
Pyro
I Beat Tetris
4.7 common "stalling" issues are bad Throttle Position Sensor, dirty throttle body/clogged idle air valve and bad plugs/wires. Since the plugs are new, I'd clean the TB and check the TPS.
