3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
coming from the front driver side....if i hit a bump it squeaks, if i sit and turn the wheel left or right it squeaks like old bed springs but if i turn the wheel ever so slowly either way it doesnt squeak...its killing me. ball joint? wheel bearing?? bushings??? i've sprayed all bushings down with wd40 and no change.
sounds like control arm bushing i had that prob on my 99 and i sprayed it with everything then ended up replacing i used energysuspension bushings and in my opinion they are the best
