02 46re trans filter
Old Jul 25, 2009 | 09:27 PM
SMKNRAM's Avatar
SMKNRAM
Default 02 46re trans filter
I am going to change filter and fluid in trans tomorrow and have read that some 3rd gens have 2 internal filters curious if that is the case for the 46re in the 02?
Old Jul 25, 2009 | 11:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IDK about the 02 but I know my 04 has two filters. When I bought them from AZ they came with both. So Im sure if you go in to buy the filters it would be the same for you.
Old Jul 26, 2009 | 01:58 AM
roadney's Avatar
roadney
mine has two filters, one is like a standard tranny filter and the other is like a regular oil filter
Old Jul 26, 2009 | 08:00 AM
SMKNRAM's Avatar
SMKNRAM
the kit I bought from oriellys only had one filter in it. I just thought I would check before getting under there, guess I will find out shortly!
Old Jul 26, 2009 | 04:49 PM
SMKNRAM's Avatar
SMKNRAM
ok, just for the record 46re only has one filter. changed and flushed tranny today and put on new trans cooler. also put the 180 t-stat in today
Old Jul 26, 2009 | 05:05 PM
ksimon's Avatar
ksimon
where did you get the bigger tran cooler
Old Jul 26, 2009 | 05:09 PM
SMKNRAM's Avatar
SMKNRAM
oriellys I got the biggest one they stock for 48 dollars
Old Jul 26, 2009 | 05:59 PM
ksimon's Avatar
ksimon
your quick, did you add it to the one on the truck? or just replace it with the bigger one. also did the SC help/ i'm new here and need some more pulling power. Thanks to all.
Old Jul 26, 2009 | 06:04 PM
SMKNRAM's Avatar
SMKNRAM
yes the sc really helped my truck, the 5.9 really wakes up, I replaced they factory cooler because it was leaking.
Old May 25, 2010 | 02:25 PM
nh5's Avatar
nh5
old thread, but where did you get the cooler? Mine's leaking also. Any aftermarket ones?
