3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I need to change the headlight assembly in an 07 Ram 1500. Looks like the tire needs to come off and the inner fenderwell needs to be removed in order to get to it. Anyone agree with that ??
Your owners manual tells you ho to remove it. There's a total of 3 bolts. 1st is in the fender well (just remove rubber plug), the other 2 are clearly visible with the hood open. After that pull pretty hard and it will pop out
