My caliper wont come off! I need help :D
Old Jul 31, 2009 | 01:00 AM
abarmby's Avatar
abarmby
Here's what the swervice manual says:
BRAKE PADS/SHOES
REMOVAL
REMOVAL - FRONT
(1) Raise and support vehicle.
(2) Remove the wheel and tire assemblies
(3) Compress the caliper.
(4) Remove the caliper, (Refer to 5 - BRAKES/HYDRAULIC/
MECHANICAL/DISC BRAKE CALIPERS
- REMOVAL).
(5) Remove the caliper by tilting the top up and off
the caliper adapter (Fig. 12).
NOTE: Do not allow brake hose to support caliper
assembly.
Al.
Old Jul 31, 2009 | 08:55 AM
sabedra211's Avatar
sabedra211
WHOO! i got the calipers off. Lol i used a butter knife stuck it inbetween the pistion and brake pad and pryed lol. the piston went back in a little bit then i stuck a flat headed screw driver for a more sturdy pry.. Then i wiggled the caliper off. It was harder to take off the bracket that holds the brake pads. those bolts were tough! But all is good new brake pads and rotors for the front .. brakes work good so i dont think i messed anythign up ! !! thanks for all the help everyone! this forum is gr8! thank you
Old Jul 31, 2009 | 09:26 AM
Rebeltilldeath3's Avatar
Rebeltilldeath3
It's okay, but you need to familiarize yourself with rule number one.
If it doesn't work, get a bigger ****ing hammer.
A BFH is the #1 tool for everything.
Old Jul 31, 2009 | 02:03 PM
hontzy87's Avatar
hontzy87
Whoa whoa whoa! hold on a minute... I thought duct tape has been labled the #1 tool.... HAHA jk jk
Old Jul 31, 2009 | 08:50 PM
Bluesmanjesse's Avatar
Bluesmanjesse
No,the Duct tape is #2 it is used to hold everthing back together after you beat the $hit out of it with the BFH,tool #1
Old Jul 31, 2009 | 08:56 PM
MontanaRAM's Avatar
MontanaRAM
bailing twine is 3rd. duck tape help my buddy's swing bar closed for his spare on his ford for 2 years when we had a flat.
Old Aug 1, 2009 | 12:15 AM
CNFD's Avatar
CNFD
#1. BFH
Tied for #2 - Duct tape to hold the s*** that moves but shouldn't and wd-40 for the s*** that doesn't move but should.
#3. JB weld.
