02 1500 2wd evap problems
Old Aug 2, 2009 | 05:42 PM
eggenz7's Avatar
eggenz7
Red face 02 1500 2wd evap problems
edit:: sorry for some reason i put 09 instead of and 02 model
went to autozone today and had my codes read. had 4 codes:
P0601
p1698
p0442
p0455
the last two are dealing with the evap system. so i crawled underneath to find a line that looks like its burnt off by the exhaust pipe.
if anybody could tell me where to find the other end of this line so i can try to repair it, it would be greatly appreciated
here is where the line originates from:
and this is where im assuming it goes up into the engine compartment.
Old Aug 2, 2009 | 05:53 PM
hemipower05's Avatar
hemipower05
what side is this on? passenger or driver?
Old Aug 2, 2009 | 06:16 PM
eggenz7's Avatar
eggenz7
drivers side just inside the frame
Old Aug 2, 2009 | 06:22 PM
hemipower05
if its the line that i found it looks like it goes up behind the block but mine seems to be capped off??
Old Aug 2, 2009 | 06:27 PM
eggenz7's Avatar
eggenz7
i looked at a 5.7 hemi and it did what your talking about. goes up the firewall a little ways and then has a cap on it. but its ziptied to a much smaller hose that continues on up..mine doesnt have that smaller hose. but after reading a little more, i believe that its only an air intake for the evap system.. now i get to tear into it to find the vacuum leak
Old Aug 2, 2009 | 06:40 PM
hemipower05
so u think the broken/burnt hose is the air intake? and now u gota find the leak?
Old Aug 2, 2009 | 07:49 PM
eggenz7's Avatar
eggenz7
correct...any ideas on possible locations that are more prone to others for leaks?
Old Aug 3, 2009 | 01:36 PM
Dskaggs20's Avatar
Dskaggs20
i have the same truck and year when i got those codes, it was cracks in the hoses that are in your second picture, the fat vacume hoses. i have part #'s at home let me know if you need them i replaced them and it was fixxed
Old Aug 3, 2009 | 06:14 PM
eggenz7's Avatar
eggenz7
i erased the codes last night..so far the only one that has come back in the p0601 code...looks like ill be buying a new PCM eventually. i can get the part for about 175..does anybody know a ball park price of getting it reprogramed for my truck?
