2 questions
Old Aug 8, 2009 | 10:46 PM
buddahead's Avatar
buddahead
Default 2 questions
1-I've ordered Hellas and am putting them behind the grille. How did you guys bolt them on? (crossbar, ...?)
2-This is a question probably for the dealer, but if I remove the last resonator for the exhaust, will the warrenty be affected?
As always, Thanks
Old Aug 8, 2009 | 10:54 PM
Pyro's Avatar
Pyro
I Beat Tetris
Drill into the crossbar, bolt the hellas on, pretty straightforward job. As for #2, your warranty will only be void on the parts modified; so if you cut your resonators off, the dealer won't warranty your exhaust, but it won't affect your warranty on anything else. In order to refuse warranty work, the dealer has to prove the modification or after market part caused the problem.
Old Aug 8, 2009 | 10:59 PM
buddahead's Avatar
buddahead
I figured it would be the crossbar. I don't have the lights yet but thought I'd ask. Thanks
