clicking in the rear
Old Aug 17, 2009 | 02:23 PM
mcgoo89's Avatar
mcgoo89
Default clicking in the rear
well 2 weeks ago i had a squeeking coming from the back two tires. i ended uo changing the pads and it was fine. but now when im accelerating there is a clicking coming from around the same area. it sounds like when you put cards in the spokes of a bike. i checked for anything that was caught up there but havent found anything. it only does it while accelerating. any thoughts?
Old Aug 17, 2009 | 02:27 PM
SilverBullet08's Avatar
SilverBullet08
sounds like maybe your gears? maybe a c-clip issue...
Old Aug 17, 2009 | 02:52 PM
mcgoo89's Avatar
mcgoo89
how do i check/fix it?
Old Aug 18, 2009 | 02:21 PM
mcgoo89's Avatar
mcgoo89
anyone?
Old Aug 18, 2009 | 04:43 PM
WildcatCody's Avatar
WildcatCody
This may not be the problem, but then again, it may.
My grandfather recently had his pads changed in his Ranger and it was making the clicking noise just like you describe in the front. Kind of sounds like they are tapping against the wheel (and I like your description of something in the spoke).
This happened because they didn't put the right kind of pads on and they were loose. You may want to check that out.
Old Aug 18, 2009 | 08:41 PM
mcgoo89's Avatar
mcgoo89
i put the pads in myself and they seemed really tight, had to tap them in with a hammer. how do i check the gears? pop off the cap and look for shavings?
Old Aug 19, 2009 | 12:36 PM
mcgoo89's Avatar
mcgoo89
any thoughts?
