Help with rust on axel!!!!
I've just powdercoated my bumpers along with painting the underbody black that was missed by the under coat. So, i was spraying the lower portion of my rear shocks when i noticed a small portion of the undercoat on the axel was pealing away. I peeled off some the undercoat and found layers of rust the axel. It look like it started from a bunch of rock chips on the axel and just started rusting away. I cleaned it up pretty good and went ahead and spray that portion with a couple coats of paint. My question is, Should i be worried? How thick is the axel as far as rusting through. Please help with any input.
the axle housing itself is pretty hefty like 1/4" thick i think? had the same prob on my truck, but it wasent painted first so i hit it with a rust inhibitor wich turned the rust black then i sprayed it black with corrosion resistant paint, and did the same to the front end
