Drivers side rear power window
Old Aug 27, 2009 | 08:39 AM
rdloghome's Avatar
rdloghome
Default Drivers side rear power window
I have a problem with my power window motor on the drivers side. The motor will go up but not down using either switch. I just tried replacing the motor ($32.00 at Autozone) and the new one does the same thing. When I hit the switch for the motor to go up it will raise the window and when it is up all the way the motor will click like it is working properly. When I hit the switch to go down I feel nothing. I used a test light in the connections and the test light will light up for both the up and down positions but I still do not get it to go down. Please help.
Old Aug 27, 2009 | 10:31 AM
nim81's Avatar
nim81
dbl check all wiring and maybe replace the switch. www.rockauto.com has them cheap
