DTC Code P0441
Old Aug 31, 2009 | 09:22 PM
bigbran's Avatar
bigbran
Default DTC Code P0441
Hi all!
First a little history. Awhile back (using this site as a guide) I fabricated and installed my own cai. Ran it for a bit in the hopes of increasing mpgs. After noticing a slight increase (1-1.5mpg) I took it off to see if the mpgs would drop with the stock cai. I did find a slight drop so I reinstalled the homemade cai two days ago. Today I got a check engine light and pulled a code P0441 which is an Evap Purge Flow Monitor error code. Was wondering if they could be related?
Thanks in advance for any and all help!
Cheers
Old Aug 31, 2009 | 09:32 PM
cheapbeater's Avatar
cheapbeater
im thinking they might be, because i used to get this code every couple weeks, but since i made my intake i havent seen it... kinda weird...
Old Aug 31, 2009 | 11:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
See if this helps you find anything.
Old Sep 1, 2009 | 10:06 PM
bigbran's Avatar
bigbran
Thanx for the reply weedahoe... I am going to try and have a look at it tomorrow and see if I cant check the whole evap system
Old Sep 1, 2009 | 10:47 PM
HammerZ71's Avatar
HammerZ71
Somebody was nice enough to put a diagram of the entire evap system in the FAQ section:
https://dodgeforum.com/forum/3rd-gen...m-diagram.html
Old Sep 8, 2009 | 12:52 PM
bigbran's Avatar
bigbran
Just a quick update for those that pull this code. Purchased a new gas cap just for fun and threw it on....check engine light disappeared after a couple starts.
Thanks for the replies!
