power door/window issues...help
Old Sep 1, 2009 | 08:50 PM
bell927's Avatar
bell927
Default power door/window issues...help
2003 dodge ram 1500 quad cab. Here is the situation: Rear passenger side power window will not operate using the master control switch on front drivers side. It will not work using the rear passenger window switch either. I used a good master switch as well as a known good rear passenger switch...still didn't work. Looks like I would need a new motor but there are the other issues: The window lock switch located on the front drivers side master control switch does not lock any of the windows and the power lock switch on the front drivers side master control switch will unlock all doors but will not lock all doors. I can lock/unlock all doors with the remote without issue and the front passenger side door switch will lock/unlock all doors no problem. Are there multiple issues/problems or is one bad part causing multiple failures? Sorry if it is confusing... I will be happy to explain better if needed...thanks in advance.
J
Old Sep 1, 2009 | 10:49 PM
Mega-Hemi's Avatar
Mega-Hemi
If the drivers switch module is good, you said you used a good one, then I would start tracing the harness through the door and into the cab. Maybe some pinched wires somewhere?
