home-brew ram air box
Old Sep 2, 2009 | 09:47 AM
nim81's Avatar
nim81
Default home-brew ram air box
finally got my new hood painted and installed and couldnt stand driving around with a non-functional ram air hood, so me and my buddy went to the local lowes and picked up some stuff and this is where it ended up.
used the bottom of the stock air box as a starting point and built everything up from there using hvac stuff and some aluminum sheet metal.
next we used a vent box end cap thing (not sure what that crap is called.) and fabbed a old light fixture from my buddys bathroom into it
then we assembled all the plumbing and filter.
painted the unit black with high temp vht flat black. (thats not me in the pic btw. he claimed i didnt know how to paint worth a dam.)
finally put everything together under the hood...
and here is my new hood in all its glory!
Old Sep 2, 2009 | 09:55 AM
oefootball_70's Avatar
oefootball_70
Looks good man, tell a difference with the ram air?
Old Sep 2, 2009 | 10:09 AM
nim81's Avatar
nim81
not from a stop, but from about 30mph+ there is def. more power!!!!
Old Sep 2, 2009 | 10:13 AM
dirtydog's Avatar
dirtydog
Moderate User
Nice job with all that fabbing needed.
couple questions.
Why the air filter that pulls hot engine heat in? Is it a straight through filter from the inside or is there filter element inside?
Are you using any filters like K&N for drop in?
Old Sep 2, 2009 | 11:37 AM
Sloooow's Avatar
Sloooow
I don't see how that would work correctly with that filter half way down the tube. Ram air works by forcing air into the intake and that would crate pressure. Having a open filter like that half way through the pressure would just release out that filter. Also if you didn't seal the hole in the factory box it would do the same thing.
Old Sep 2, 2009 | 11:56 AM
dunerider650's Avatar
dunerider650
Yea...what i would of done is thrown a k and n drop in into the stock box then flipped the box upside down and made mounts and induction....
Old Sep 2, 2009 | 01:52 PM
08DodgeTRX's Avatar
08DodgeTRX
A for effort, and the hood looks great, but I think you could do the ram air better.
If your keeping your current setup I hope you closed the hole in the front of the stock air box, we can't tell from the pics, but you gotta git rid of the filter half way through. Any pressure your building is definitely being released right there.
I would suggest this.....
Using PVC, make a pipe that uses the stock opening in the front of the air box as the output of the ram air box towards your throttle body. Replace the adapter you made with another, obviously with out that hole in it. Put a drop in filter in the box.
So what will happen is, air flows into your hood, get pushed into the adapter you made down into the air box, gets filtered by the drop in, gets pushed out the front of the air box where your pvc intake takes it to your throttle.
And make sure you weld or jb weld all the edges. If there is anywhere for pressure to escape, it will.
