quick help about turn signal bulbs
Old Sep 8, 2009 | 03:29 PM
JJn5526's Avatar
JJn5526
Default quick help about turn signal bulbs
ok guys i wanna find turn signal bulbs that blink but when i turn the running lights on they wont glow.. i have the Halo angel eyes and LEDS so i dont want the amber glow but i need blinkers of course, right now im not running any front turn signals.. do any of you guys know if any company makes turn signal bulbs that just blink and not stay on? i tryed googling kit but i cant find anything really.. thanks guys
Old Sep 8, 2009 | 03:34 PM
Shiloh 24's Avatar
Shiloh 24
I'm thinkin that something has to be wired wrong for them to do that. Something isn't allowing the blinker to work properly, if the back is working then it has nothing to with anything as far as blinkers that came stock on the truck. It has to be in the headlights. Check your wires to make sure they're all correct.
Old Sep 8, 2009 | 03:36 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
is it a 3157 bulb? cut the middle wire going to the bulb, this should be the same wire that you wired into the leds to light them up (leave room to reattach it in case i'm wrong).
Old Sep 8, 2009 | 04:48 PM
Spokane_Dodge's Avatar
Spokane_Dodge
I know they have 2-way turn signal bulbs that will be white for the running lights and yellow for the blinker. Never seen any that are off for running lights.
If you want the halos on without the running light, the easiest thing to do would be to not have them ran into your running lights. Make it a seperate switch for the Halos.
Old Sep 9, 2009 | 01:20 AM
JJn5526's Avatar
JJn5526
yea theres no problem at all i worded my explaination wrong.. nothings wrong with the wiring or the connectors or anything i was just wondering if they made a bulb that wont glow when running lights are on but will still blink when you use the turn signals.. thanks tho for the help..
Old Sep 9, 2009 | 04:16 AM
VP64's Avatar
VP64
the running lights have 3 wires. one for the runnning light, one wire for the blinkers, and the other is ground. so just cut the running light wire
