p0171 p0174???
Old Sep 9, 2009 | 10:37 PM
05BIGHORN's Avatar
05BIGHORN
Default p0171 p0174???
2 codes p0171 and p0174 (bank 1 and 2 too lean)my truck is sputtering and spitting all through the rpms unless i floor it and was wondering if i need to get a new fuel pump. i googled the codes and i dont think i have a vac leak and it says a good chance its the fuel filter but says nothing about fuel pump... what you think.
sound and vid quality suck but you can tell when it sputters and after i was done taking the vid i went to turn around and then it died on me in as i was hitting the throttle in reverse but it fired right back up and sputtered on home.
http://s82.photobucket.com/albums/j2...t=CLIP2088.flv
Old Jan 7, 2010 | 06:18 AM
Blake James's Avatar
Blake James
i am having the same problem did u ever figure out what it is?
Old Jan 7, 2010 | 06:24 AM
RamIt33's Avatar
RamIt33
Ouch that sounds bad... Iunno what that could be, all i can suggest is that maybe you may have a leak of some sort, maybe installing a new fuel filter.
Old Jan 7, 2010 | 06:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This might help you out......maybe
B/C/P/U 2004-2006 codes in full details from AllData
Old Jan 7, 2010 | 01:03 PM
That1guy's Avatar
That1guy
Mine will ever so often start up funny like it almost dies but catches itself. It's never sputtered while driving.
