Whats up with this??
Old Sep 10, 2009 | 10:30 PM
04Phantom's Avatar
04Phantom
Default Whats up with this??
Alright, i just got done changing my spark plugs, rear diff fluid, oil, put my shift kit in, and changed the tranny fluid. Now here's my question, when i turn my key in the On position, the throttle body flapper like shakes a few times, stops, then does it really quick again, Do the hemis normally do this and i havent noticed? Or is something wrong here? any help would be appreciated!
Old Sep 11, 2009 | 01:48 AM
04-fourseven's Avatar
04-fourseven
It shakes? Have you actually watched this? thats kind of weird. take a vid, I want to see that!
Old Sep 11, 2009 | 03:16 AM
RubberFrog's Avatar
RubberFrog
You sure you're not just hearing the fuel pump?
Old Sep 11, 2009 | 02:29 PM
04Phantom's Avatar
04Phantom
Im positive its not the fuel pump, i had my intake off of it when it first did it.. I'll take a vid of it..
Old Sep 11, 2009 | 04:05 PM
jdfisher's Avatar
jdfisher
It is normal if your truck is a drive by wire for the TB plate to move, the ecm is verifying operation and setting it to start. If you have a tuner you can monitor throttle position. It will fluctuate between 8-12-17 and settle at 17% for the start and once your truck warms up it should settle to about 12% idling.
Old Sep 11, 2009 | 07:17 PM
turbot_bird's Avatar
turbot_bird
OK, I was thinking it was just verifying that it was working too. the throttle plate just moves a few times then settles for startup.
