removing rev limiter ...
Old Sep 11, 2009 | 05:37 PM
cyclone429's Avatar
cyclone429
Default removing rev limiter ...
Has any one done this with a tunner and how are thier any fail safes to prevent your hemi from taking a trip into outter space?
When I'm in race car mode with a my 2500 hemi that is not made for racing, I can't go over 4000 rpm in any gear, rev limier shuts down the engine.
How high can a 5.7 run ( rpms ) in stock mode.
I do understand I don't have a drag racer, but lately I'm driving my truck like a racer, I'm having lots of fun with 5.0 mustangs ...
Old Sep 11, 2009 | 06:01 PM
truckin151's Avatar
truckin151
You can set them using the Superchips or Diablo. They have a rev limit setting where you can set it to thier maximum setting, Superchips is 6500 I believe and Diablo is 7500 if Im not mistaken while in drive. I have mine set to 6100 which is more than enough. Diablo has a setting though where you can raise the rev limit for park/nuetral from 4000 up to 6000 (without it sitting in front of me I couldn't tell you how high it can go up to) but there is really no reason move that one unless you want to hurt something.
Old Sep 11, 2009 | 06:30 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, as said, SC is 6500. Ive done it on mine and I can spin way on up there if I want (and sometimes do)
Old Sep 11, 2009 | 10:42 PM
dirtydog's Avatar
dirtydog
Moderate User
4,000 is the rev limit in neutral only. i assure you your engine shifts at 5600 or so rpms in every gear WOT.
As others stated, a handheld tuner will allow you to raise both of those features higher. Problem is, the Hemi doesn't make any power past 5300rpms. It drop like a rock after that. Some have reported quicker E.T's raising up to 6k by .2 & .3tenths
