1500 Hemi Rotten egg smell and code 132
Old Sep 14, 2009 | 11:49 AM
xTomKx's Avatar
xTomKx
Default 1500 Hemi Rotten egg smell and code 132
My truck has the rotten egg smell. I pulled the codes yesterday and got code 132. Would that mean that the cat is toast? Is code 132 the front 02 sensor?
Old Sep 14, 2009 | 02:18 PM
SSFF's Avatar
SSFF
Rotten egg smell, that's sounds like the cat. But that your code points to an O2 sensore:
P0132 O2 Sensor Circuit High Volts (Bank 1 Sensor 1).
Since the O2 sensor is alot cheaper, I would start there first.
Old Sep 15, 2009 | 08:11 AM
xTomKx's Avatar
xTomKx
But if the cat is clogged isn't that going to screw up the new o2 sensor too?
Old Sep 15, 2009 | 08:19 AM
Pyro's Avatar
Pyro
I Beat Tetris
best way to unclog a cat is go on the highway and blast the carbon buildup out of the pipes...
Old Sep 16, 2009 | 08:26 AM
xTomKx's Avatar
xTomKx
I started tinkering with the truck yesterday. Turns out code 0132 means that the oxygen sensor voltage is high. So I plugged in a obd scanner and sure enough I am getting 1.075-1.250volts from the front o2 sensor, where the reading is supposed to be 0-1volts. I got a new bosh oxygen sensor, installed it and I'm still getting the same thing. Since I had the front oxygen sensor out I decided to do a little test. Started the truck and put my finger over the sensor hole to see how much back pressure I would get. To my surprise I didn't get very much back pressure. With the sensor hole still open I checked the tailpipe and I was getting good exhaust flow there.
I also checked the pins on the computer (the one on the firewall) to see if there was any bent/damaged pins. Everything looked good.
There are three things I'm suspecting:
1. wiring to the oxygen sensor is shorted out.
2. ecu is damaged.
3. cat is damaged - not likely due to the test above.
