2006 dodge ram big horn slt radio diagram
Old Sep 24, 2009 | 10:49 PM
Dcwhat's Avatar
Dcwhat
Default 2006 dodge ram big horn slt radio diagram
hey i have a 2006 dodge ram 1500 quad cab big horn SLT. I need a wiring diagram, i'm not sure if i have a an infinity stereo, i dont think i do. but a standard 4 speaker wiring diagram thank you.
Old Sep 26, 2009 | 02:18 PM
Dcwhat's Avatar
Dcwhat
repost
Old Sep 26, 2009 | 02:49 PM
chambers's Avatar
chambers
Do you just need to know what each wire is or do you need to see an actual diagram of how they are run through the truck? This site has some wiring info on various vehicles http://www.the12volt.com/installbay/...ard/Dodge.html
Old Sep 26, 2009 | 04:08 PM
05RamMan's Avatar
05RamMan
This what you want?
Old Sep 27, 2009 | 12:31 PM
Dcwhat's Avatar
Dcwhat
Yeah I think so just looking for the color codes on the wires what they are for and find an ignition wire
Old Sep 27, 2009 | 12:40 PM
Markmm0000's Avatar
Markmm0000
if you have infinity system and your doing a radio goodluck.
Old Sep 27, 2009 | 08:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dodge 2006 Ram Pickup EX. CAB Pickup
(PREMIUM SYSTEM)
RADIO HARNESS Wire FunctionColorNoteFuse #SizeLocation+12V DC Battery(Constant)Gray/red Radio pins 1 & 12 11 20 amp Integrated power module at left front fender Switched AccessoryData Ground Black Also black/light green Left Rear + Dk.green/dk.blue Line level output Left Rear - Dk.green/orange Line level output Right Rear + Gray/dk.blue Line level output Right Rear - Gray/orange Line level output
AMPLIFIER OUTPUTS Wire FunctionColorNoteFuse #SizeLocation12V DC BatteryYellow/red Amplifier pins C1-4 & C1-13 36 25 amp Integrated power module at left front fender Remote Turn On (input) N/A See notes for B+ & accessory power to subwoofer amplifier. Left Front Mid + Dk.green/yellow Left Front Mid - Dk.green/lt.blue Left Front Tweeter + Gray/orange Left Front Tweeter - Gray/yellow Right Front Mid + Gray/yellow Right Front Mid - Gray/lt.blue Right Front Tweeter + Gray/dk.green Right Front Tweeter - Gray/lt.green Left Rear Mid + Gray/lt.green Left Rear Mid - Gray/dk.green Right Rear Mid + Dk.green/lt.green Right Rear Mid - Dk.green/gray Center Channel + Gray/brown Center Channel - Gray/orange Subwoofer 1 + Dk.green/tan To the subwoofer amplifier Subwoofer 1 - Gray/tan To the subwoofer amplifier
AT SPEAKERS Wire FunctionColorNoteRight Rear Mid + Gray/lt.green Or dk.green/lt.green Right Rear Mid - Gray/dk.green Or dk.green/gray Subwoofer 1 + Gray/brown Channel 1 of subwoofer speaker. Subwoofer 1 - Dk.green/brown Channel 1 of subwoofer speaker. Subwoofer 2 + Gray/white Channel 2 of subwoofer speaker. Subwoofer 2 - Dk.green/white Channel 2 of subwoofer speaker.
Available Notes Notes The SUBWOOFER AMPLIFIER, has B+ at pin 2 (red) with fuse no. 24 of 20 amperes in the integrated power module; the accessory line (pink/yellow) goes to pin 3 & has fuse no. 39 of 10 amperes.
The main amplifier is located at right side of dash, but the woofer amplifier is at left side of body.
Old Sep 28, 2009 | 11:48 AM
Dcwhat's Avatar
Dcwhat
here is the back of the radio, i only count 4 speakers worth of wiring not sure maybe you can help.
Old Sep 28, 2009 | 11:53 AM
Dcwhat's Avatar
Dcwhat
here is the radio flipped over
Old Feb 22, 2011 | 05:42 PM
06hemi1500's Avatar
06hemi1500
Does anyone know that the white wire and the white and orange wire are for?
