Ignited Push button starter
Old Sep 24, 2009 | 11:49 PM
mc35's Avatar
mc35
Question Ignited Push button starter
just ordered it today....but i have a question before i put it in. like many others, im gonna place it in the existing cigarette lighter to the left of the radio bezel. however, that cigarette lighter does not work. i dont know why it doesnt work, it just will not heat up and no power gets to it when things are plugged into it. is this going to be a problem with the starter? if it is, what will i need to do?
Old Sep 25, 2009 | 12:02 AM
OklaHemi's Avatar
OklaHemi
check your fuse.
Old Sep 27, 2009 | 09:37 PM
mc35's Avatar
mc35
fuse is perfectly fine. power is getting lost somewhere in the line....what all wires will i need to do this push button starter? will i even need the power line from the cigarette lighter? any help is appreciated...
Old Sep 27, 2009 | 09:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You dont need power from the lighter. You will need to go under your steering wheel and find the starter wire and but it and route on side to the switch and the other wire to the other side of the switch.
Now IDK but if that button is illuminated and you want it that way when yeah you might need 12v from somewhere but you can also pull that from the AC controls or radio.
Old Sep 27, 2009 | 10:28 PM
mc35's Avatar
mc35
thanks. and yes it is illuminated so i guess i will have to pull a 12v from somewhere as you stated.....sorry electrical stuff is not my point of knowledge haha.
Old Sep 28, 2009 | 11:23 PM
oneHEMI57's Avatar
oneHEMI57
MC35, I've had thoughts of doing the change over too. Where did you find a suitable switch to fit the cigar lighter port? Did you every find out the cigar ltr port is powered w/the ignition coluum switch is on, only?
I guess the sw doesn't have to be push button, could be a momentary-on toggle as is found all over an aircraft cabin. Had a thought to install the sw near the base of the dvr's seat.
I'm going to search my DC shop manuals to see which leads to be disconnected from the steering coluum sw and run out to the remote located sw.
Old Sep 28, 2009 | 11:54 PM
mc35's Avatar
mc35
I found the blue Ignited push button off of stylin trucks. here it is...
http://www.stylintrucks.com/parts.as...rtfamilyid=491
however...i got it on amazon for like 30 bucks.
