Check Engine light
Old Oct 1, 2009 | 03:01 PM
jstmahoney's Avatar
jstmahoney
Default Check Engine light
Hey guys, I need some help again! My check engine light came on today! The ironic thing is, i just took my caliber in to the dealer today! Something else to fix! I pulled the codes but I need your help to figure out what they mean.
so here they are
P0456
P0591
thanks
justin
Old Oct 1, 2009 | 04:56 PM
dunerider650's Avatar
dunerider650
P0456 = emissions system leak
p0591 cant find anywhere....???
Old Oct 1, 2009 | 04:57 PM
dunerider650
p0591-speed control switch 2 performance
Old Oct 1, 2009 | 05:01 PM
jstmahoney's Avatar
jstmahoney
now i looked them up and i was wondering about the p0456. On another forum it was saying that could come up due to a loose/warn out gas cap. but the code p0455 is loose gas cap. What does ether of these codes translate in to in pure English
Old Oct 1, 2009 | 05:08 PM
nim81's Avatar
nim81
in my superchips manual p0591 is cruise control multi-function input b circ range???????
the other one could be a bad hose on your evap system
Old Oct 4, 2009 | 06:01 PM
jstmahoney's Avatar
jstmahoney
OK so i checked it out. looks like I need a new pcv valve and I found another hose that needs replacing. Anyone know how much pcv valves run?
EDIT:
mopar parts america:
MSRP: $34.80
Your Price: $26.69
Old Oct 4, 2009 | 06:26 PM
HammerZ71's Avatar
HammerZ71
cruise is vacuum controlled, so it's possible fixing one will fix both...
Old Oct 4, 2009 | 07:01 PM
Drangiz's Avatar
Drangiz
I think PO456 is a small leak in the EVAP system. You can try replacing the gascap, or the hoses on the unit itself. I had to do the hose replacement recently and it is really easy and cheap. I don't have the part numbers on me at the moment but there are two small hoses on the unit. The unit itself is under the truck bolted to the inside of the driver side frame rail, near the rear seat. The hoses are about 6 inches long and are the pre-bent type. All you do is get the hoses, yank off the old ones and pop on the new ones, that is it. If I remember right, each hose is like 6 or 7 bucks from the dealer so for about 15 bucks your problem is solved.
EDIT:
Here are the part numbers.
52121100AA
52102793AA
Old Oct 4, 2009 | 07:08 PM
jstmahoney's Avatar
jstmahoney
thanks guys
Old Oct 8, 2009 | 11:17 AM
jstmahoney's Avatar
jstmahoney
I got the hoses and the pcv valve. Funny thing is the check engine light went off before i replaced the parts! Guess It was ether the gas cap or the tape i put on the cracked hose. PS: While I was at the dealer, I was looking at a new Jeep Cherokee. I loved it! Black on black, very nice...May trade in the caliber in a few years so I'm looking!
