E-Fan installed but one question.
Old Oct 4, 2009 | 05:34 PM
tank410's Avatar
tank410
Thumbs down E-Fan installed but one question.
Hey Guy This is my first post. I got my truck( 2007 4.7L QC 2WD) about a month ago. My first upgrade was to put an E-Fan. I found the write up by Off_Road_Teacher on here. So I went to getting parts, I got a Taurus fan,a flex-A-Lite fan controller, and the other parts he used. I started yesterday installing.
Here is my question. The clutch fan post/nut holds the water pump pulley on. What size nut fits it?
I have everything installed and working but with out that nut I had to put the clutch minus the fan blades back on to keep the pulley in place.
I thought about cutting the post/ nut off and using it. But then I would have to buy another clutch if I ever wanted to go back.
Any help would be great.
Thanks
Tank
Old Oct 4, 2009 | 06:31 PM
SilsHemi's Avatar
SilsHemi
The pulley is pressed on and will stay in place. You don't need a nut or clutch without the blades.
Sil
Old Oct 4, 2009 | 06:55 PM
MikeHTally's Avatar
MikeHTally
The nut is not necessary. I used a great big crescent wrench to get the nut off. I'd guess it's a 1 1/4", but I don't know. A spanner is helpful to hold the water pump pulley. Some folks have jammed screwdriver or whatnot into the holes in the pulley.
Old Oct 4, 2009 | 08:32 PM
BEAR's Avatar
BEAR
Sil
The pulley should stay on without the nut.
Old Oct 4, 2009 | 08:49 PM
WWJD's Avatar
WWJD
got pics of the install?
