throttle control
Old Oct 5, 2009 | 10:10 PM
rkrsquared2's Avatar
rkrsquared2
Default throttle control
ok im at a loss, i have a rough idle while in gear, hesitation on acceleration, codes p0113, p0123, p0132, p0222, p2111 and p2106 i have changed the o2 sensor, the map sensor, removed and cleaned the throttle body, reset computer and codes come back after a couple of days of driving and the acceleration issue returns, before i spend the money on the throttle control is there anything else i could try, please help, thanks in advance, oh i guess you should know its on a hemi 5.7l
Old Oct 6, 2009 | 07:51 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the correct section if you tell me the model and year of your Hemi,
FF
Old Oct 6, 2009 | 07:26 PM
rkrsquared2
oh thanks, 2003 dodge 3500, 5.7l hemi
Old Oct 6, 2009 | 07:37 PM
1969CoronetR/T
vaffanculo
I will move the thread to the third generation Ram section,
FF
Old Oct 6, 2009 | 08:04 PM
Pyro's Avatar
Pyro
I Beat Tetris
P0113 Intake Air Temp Sens Voltage Hi
P0123 Throttle Pos Sens Voltage Hi
P0132 1/1 O2S Shorted To Voltage
P0222 APP Sens2 Circ Low Voltage
P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
P2111 Throttle Actuator Ctrl Sys-Stuck Open
Check your electrical connections for shorts, make sure you installed your new sensors correctly and calibrated them.
Old Oct 6, 2009 | 09:32 PM
rkrsquared2
please excuse my ignorance, but just how do you go about calibrating an O2 sensor
Old Oct 6, 2009 | 10:06 PM
Pyro's Avatar
Pyro
I Beat Tetris
You can't, ignore the "calibrate" part of my post, I thought you installed a new TPS sensor as well. Although you should check to see if you damaged the TPS when you cleaned the TB.
Old Oct 6, 2009 | 10:45 PM
rkrsquared2
well its my understanding that the TPS is incased within the TB so i dont think i could damage it, please correct me if im wrong
