Power Steering Pump
I have an 02 Ram 1500 quad cab 4wd and am going to be changing the power steering pump,the pully looks like it has a allen head in the center,does anyone know if that will just unbolt or is it the pressed on kind>Also if it unbolts would it be reverse thread?Thanks
If I recall correctly, that is a pressed on pulley. You'll certainly know when you get the new one! You may even need to re-use your reseviour tank too???? Depends on the reman unit. manufacturer
