Electric water pump
Old Oct 12, 2009 | 04:23 PM
tk04hemi's Avatar
tk04hemi
Default Electric water pump
Is there an electric water pump for the 3rg gen dodge ram? Or does everyone just use the OEM replacement? Thanks
Also when changing spark plugs, is there anything to be gained from different coil packs, wires etc? When something goes I try and replace it with the best
Old Oct 12, 2009 | 09:13 PM
MikeHTally's Avatar
MikeHTally
I believe there is an electric water pump. I also believe you could buy several replacements for the OEM unit for what they cost. If your plug wires are in need of replacement, 8.2mm are apparently good bets. Probably no real performance improvement, but you may get a smidge.
