So....
Old Oct 13, 2009 | 11:55 AM
OklaHemi's Avatar
OklaHemi
you only turn the key to acc on then push start. you tie into your 12v from your cig lighter and the yellow wire off the ignition. i posted some picks i think last week. i dont have it done yet but it is on my short list. i know another member on another forum did the whole key fob set up like the nissans have, no key necessary. but it is like a 400.00+ set up and you will have to cut a key down and leave your truck turned to on all the time like he did or find a way to disable the steering wheel lock. the srt-10 is an easy set up maybe 10-15 min install. plus major cool points
Old Oct 13, 2009 | 12:02 PM
SilverBullet08's Avatar
SilverBullet08
yea i know dominiontx did that. maybe ill do the srt button later but right now ill focus on other mods.
Old Oct 13, 2009 | 12:08 PM
truckin151's Avatar
truckin151
The problem I see with the key always on is the programmer. When loading a tune you have to be able to turn the key on and off. So that would be a big no there. After looking up some things I think I am going to lean more towards lights or just a cover to "patch" the hole for now.
Old Oct 13, 2009 | 12:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Youre right about turning the key but you only turn it to turn the accessories on and not bump the starter so with a tuner you will still be ok.
But hey, I will be adding a push button soon also
Old Oct 13, 2009 | 12:55 PM
cheapbeater's Avatar
cheapbeater
stick one of these http://www.roadkillcustoms.com/hot-r...ntory/1710.jpg in there... then when someone says "what does this do?" you can pretend like it is something really cool, and tell them not to touch it whatever they do...
Old Oct 13, 2009 | 01:03 PM
ramhunter9's Avatar
ramhunter9
add another 12v socket ..you cant have to many of them
