cam
Old Oct 13, 2009 | 09:55 PM
grayth_55's Avatar
grayth_55
Default cam
is there anyway to put a bigger cam in our 3.7 v6. im just wandering if there is
Old Oct 13, 2009 | 10:34 PM
Twink's Avatar
Twink
as far as i know there is not a aftermarket cam.. I had mine in for a mild grind.. if u can find a good motor shop they can pretty much tweak ur stock cam a bit to get more air/fuel etc out of it.. Call around to some shops and see what they think..
Cheeers
Old Oct 14, 2009 | 09:44 AM
grayth_55's Avatar
grayth_55
is there a way you can put a bigger cam from the bigger v6's dodge makes or would that be pointless
Old Oct 14, 2009 | 04:15 PM
Freakinkeith806's Avatar
Freakinkeith806
I doubt there is, do what Twink said and maybe get it tweaked a little
Old Oct 15, 2009 | 10:12 AM
Twink's Avatar
Twink
not worth it.. but its cheap to have ur stock one machined a bit
Old Oct 15, 2009 | 04:03 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
i'm pretty sure several people make them.
this place in florida...
Old Oct 15, 2009 | 04:04 PM
derricksmash
V6 Ram Moderator
krc performance. site's down right now...but check 'em later.
Old Oct 15, 2009 | 04:20 PM
chambers's Avatar
chambers
I'm pretty sure KRC only has them for the 3.9's, I think they said there was never any demand for the 3.7 so they never made one. Shoot them an email if you're really interested.
Old Oct 15, 2009 | 05:21 PM
grayth_55's Avatar
grayth_55
alright thanks guys. im also looking at these stinger injectors from airram.com
Old Oct 25, 2009 | 12:50 PM
xanadu62's Avatar
xanadu62
I was just going to have a set custom ground for mine. I was wondering about those injectors. Which ones do you think I need? And for that matter, what are the specs for the stock ones? I am going to boost mine, and I need to know what the stock ones push so I can compensate for the extra airflow. After that, I am going to send my ecu to B&G to tune it fully.
