Im getting 10.7 mpg....wtf
Old Oct 14, 2009 | 12:06 PM
truckin151's Avatar
truckin151
If everything has been cleaned and replaced, then do the test over again. Actually log the miles so you know exactly how far you went and start with a full tank. When you refill the tank take the number of miles you drove and divide them by of gallons you put back in the truck.
Old Oct 14, 2009 | 12:14 PM
OklaHemi's Avatar
OklaHemi
the rams hav a 2 gallon reserve tank. so after you light comes on and your overhead reads 0 you still have a bout 2 gallons in the tank. i used to run my 3.7 about 40 miles after the light came on every time when i drove to colorado every week. i never got more than 23 in the tank. i had the trip laid out two stops and i was in rifle. make you a power wire i am seeing a 1.5/2 mpg difference driving easy
dunerider650's Avatar
dunerider650
ok i guess ill wait and redo it just didnt think it would make that much difference.
Old Oct 14, 2009 | 12:27 PM
dunerider650
k even if i only went 229 miles and used 18 gallons that's still 12.7 mpg........
Old Oct 14, 2009 | 12:43 PM
MarvOhio's Avatar
MarvOhio
my overhead says 11.7 religiously never have calculated it by hand thou im afraid to... i also dont do much freeway driving
Old Oct 14, 2009 | 12:50 PM
dunerider650
yikes....as long as im not by myself i guess there isnt anything wrong....
Old Oct 14, 2009 | 12:58 PM
truckin151's Avatar
truckin151
What tune are you running with your cortex? How is the tire pressure?
Old Oct 14, 2009 | 12:59 PM
SilverBullet08's Avatar
SilverBullet08
i get 12.4 on the overhead but i drive like a bat outta hell lol
Old Oct 14, 2009 | 01:13 PM
dunerider650
Tire pressure is right around 36 or something just enough to keep the tire pressure monitor off....im running the SC 91 tune. Could a egr valve be that bad??? it hasnt thrown a code or anything but would it if it was bad???
Old Oct 14, 2009 | 01:15 PM
SilverBullet08
it might be going out... im going to change mine out here soon
