Question on key activated alarm
Old Oct 15, 2009 | 12:08 PM
NC FF/PO-PO/EMT's Avatar
NC FF/PO-PO/EMT
Default Question on key activated alarm
Does anyone out there know how to get the horn to stop activating when you hit the alarm button on the key? I've got a 2006 2500. My wife's 06 Charger doesn't do this - it merely flashes the lights. If I could get the Ram to match that, I'd be a happy camper.
Thanks!
Old Oct 15, 2009 | 12:46 PM
dakotaff's Avatar
dakotaff
My Dakota does this too. Would love an answer.
Old Oct 15, 2009 | 12:52 PM
bwhite757's Avatar
bwhite757
The horn chirp feature will be shipped from the assembly
plants activated. If desired this feature can be disabled by
using the following procedure:
1. Perform this operation while standing outside the
vehicle.
2. Press and hold the LOCK button on a programmed
(i.e. functional) key fob.
3. Continue to hold the LOCK button, wait at least 4
seconds, but no longer than 10 seconds, then press and
hold the PANIC button. Release both buttons at the same
time.
4. To reactivate this feature, repeat the above steps.
Vehicles will be shipped from the assembly plants with
the park lamp flash feature activated. If desired, this
feature can be disabled by using the following procedure:
vehicle.
2. Press and hold the UNLOCK button on a programmed
3. Continue to hold the UNLOCK button, wait at least 4
hold the LOCK button. Release both buttons at the same
time.
Page 21 in the owners manual...
Old Oct 15, 2009 | 12:58 PM
josemer09's Avatar
josemer09
Its very easy i did this last week because it annoyed the heck out of me....all you have to do is go out side and press and hold the Lock button and hold it for more than 4 seconds but less than 10 seconds then you press Panic button while holding the lock button down then you release both buttons at the same time and if you want to turn it back on all you have to is repeat the same steps.
