slotted and drilled rotors or stock OEM
Old Oct 17, 2009 | 08:57 PM
ramhunter9's Avatar
ramhunter9
Default slotted and drilled rotors or stock OEM
i no the difference is heat disapation but im in the market for new rotors for the 7800 pound beast i noticed today while braking a sputter so im thanking rottors or brake pads i havent had time to check yet as i just got home and have a case of the dreaded mud but ( tia food evertime ) so i will be inspecting them in the morning . but what other pros and cons are there between the 2 rotors ...i may get lucky i could get them turned for 20 bucks as they run 160 bucks a pop new and i might get lucky it may just be pads.
Old Oct 17, 2009 | 09:04 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Here is a little info about them. Just one thing to keep in mind is that some guys who have put drilled rotors on the heavier trucks have had problems with the rotors cracking.
Slotted Rotor Attributes:
- The slots on the rotor helps clean the brake pad, which improves bite.
- The slots on the rotor will slice the brake pad allowing the pad to bite harder into the disc causing an increase in disc temperatures. This will bring your brakes up to temperature faster , but might also take you too far decreasing the benefit. The slotted rotor coupled with a race pad which need to be heated would be optimum.
- Slotted rotors will also cause slightly more brake pad wear and tear giving you less miles on a pad before it needs to be replaced. Shorter maintenance schedule.
- Slotted rotors allow gas to ventilate during brake fade.
- Slotted rotors are less prone to cracking then the cross drilled rotor.
- Slotted rotors have more disc surface.
- Slotted rotors maintain around 96% of the friction surface
Drilled Rotor Attributes:
- Drilled Rotors offer an enhanced initial bite.
- Drilled Rotors perform better in wet weather over the slotted rotor. Due to volume of a hole vs a slot.
- Drilled Rotors are more prone to cracking than slotted.
- Drilled Rotors allow gas to ventilate during brake fade.
- Drilled Rotors offer a performance benefit since there lighter in weight.
- Drilled Rotors have more ventilation so they should cool off faster , but have less rotor material so they could get hotter than a slotted rotor. But its hard to say as the slotting also increases heat.
- Drilled rotors maintain around 85-93% of the friction surface
Drilled and Slotted Attributes:
- Drilled and slotted are the least reliable.
- Drilled and slotted are going to weigh less from the same manufacturer. Other designs might be lighter from company to company.
- Drilled and slotted will give the most performance benefit to acceleration due to the lighter weight.
- Drilled and slotted will also be the hardest on your brake pad (wear and tear)
- Drilled and slotted only maintain 80-91% of the friction surface
Old Oct 17, 2009 | 09:08 PM
ramhunter9's Avatar
ramhunter9
wow nice find teach!! you thinkin what im thinkin rotors or pads right
Old Oct 17, 2009 | 09:10 PM
Off_Road_Teacher
Yeah, if you are getting that sputter only when you are using the brakes it is probably rotors or pads.
Old Oct 17, 2009 | 09:55 PM
HemiLonestar's Avatar
HemiLonestar
Time for some Power Slot's!
