Water pump leaking after radiator fluid change?
Old Oct 20, 2009 | 04:01 PM
WWJD's Avatar
WWJD
Default Water pump leaking after radiator fluid change?
Right after I got the radiator fluid changed my water pump started leaking. The shop that did it just said "sometimes that happens". Is there something they did wrong perhaps?
Old Oct 20, 2009 | 07:16 PM
MikeHTally's Avatar
MikeHTally
Not likely. How many miles? Water pumps are easy to change and not horribly expensive. Just be ultra-careful with the coolant. Make sure you capture it all, and don't let any escape.
Old Oct 20, 2009 | 07:44 PM
canadian wheeler's Avatar
canadian wheeler
I use to manger a quick lube place. Every now and then when we would do a radiator fluid change customers would come back with there water pumps leaking. Some time they get all gunked up from the old fluid and doing a flush just breaks it all loose. Maybe ask the shop to split the cost with u? Wouldn't hurt.
