Any Advice?
Old Oct 23, 2009 | 02:07 PM
huseman808's Avatar
huseman808
Default Any Advice?
I had a code pop up today, P0420. Its on my 2003 Dodge Ram 1500 with the 5.9L. I have just about 102,000 miles on the truck.
P0420 (M) 1/1 Catalytic Converter Efficiency Catalyst 1/1 efficiency below required level.
I have heard that it could be the Cat itself or the downstream O2 sensor. I was just wondering if anyone has had this or what they did to troubleshoot this code.
Im on a limited budget, so if I buy the 80$ O2 sensor I want it to work. And a Catalytic Converter costs around 80$, or so ive been told.
Thanks in advance.
EDIT: i did hit the 0 one too many times
Old Oct 23, 2009 | 02:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well I can promise a Cat isnt going to cost 800 bux. P/N 99205HM from Autozone is 80. So maybe you put too manu zeros in there, IDK
I can get you the code info from Alldata later tonight when I get home.
Old Oct 23, 2009 | 02:56 PM
truckin151's Avatar
truckin151
Yeah even the highflow performance cats are only $80 so there is no way that your cats is going to be $800... unless you are talking about the fine for not having one on lol then you are looking a little more than that...
