Those with HIDEXTRA Kits... (06+ only)
Old Oct 27, 2009 | 10:59 PM
damien1023's Avatar
damien1023
Its really not that bad of an install. Just make sure you have everything plugged up correctly. The hardest part is finding a place to mount the ballasts.
Old Oct 28, 2009 | 10:10 AM
dirtydog's Avatar
dirtydog
Moderate User
That is exactly how it should be. i would reccomend buying 55w resistors to splice into your factory plugs. This way you won't have any issue's with flickering or lamp out indicators. i haven't run my HID's more than an hour or 2 so i cannot say if mine will never flicker? Or the easiest solution is to buy Cancellor kits like THESE
Old Oct 28, 2009 | 10:56 AM
damien1023's Avatar
damien1023
If you havent seen it, i doubt you will dog. This can happen to me within a 5 minute trip home.... im assuming i only need 1 of those cancellor kits since im only using the drivers side plug correct?
Old Oct 29, 2009 | 11:42 PM
damien1023's Avatar
damien1023
UPDATE: Getting some cancellors shipped out to me. Will let everyone know the results... i guess no one else is having a problem though? This is weird...
