Blocks?
Old Nov 3, 2009 | 01:39 AM
blackram1500's Avatar
blackram1500
Smile Blocks?
Where is a good place to order 2" rear blocks?
Old Nov 3, 2009 | 02:12 AM
OlDirtyJohn's Avatar
OlDirtyJohn
i heard autozone or one of those places has em cheap. weed will chime in soon on exactly where soon hopefully
Old Nov 3, 2009 | 07:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, AZ has them for about 30 a set. That where I bought my 1" blocks from. The block bolts arent wide enough to precisely fit the axle so all I did was get my hammer and tap them on and then use the C clamp to push the ends back together to line up with the holes in the blocks. Once you get past that you are fine.
Old Nov 4, 2009 | 12:32 AM
blackram1500
Default Blocks
Is it needed to get the rear aligned after putting the new blocks on? I will also have picks of my upgrades too my truck soon..a couple more things first.
Old Nov 4, 2009 | 01:51 AM
OlDirtyJohn
no you will not need an alignment on your rear end.
Old Nov 4, 2009 | 07:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It took me maybe 90mins to put both sides on mine, just make sure you have a c clamp
