Help with Brake line nut Sizes
Old Nov 6, 2009 | 03:43 PM
LChavez's Avatar
LChavez
Default Help with Brake line nut Sizes
Hey guys. Anyone know the size of nut in the rear brake line where it "T's" to the two rear calipers? Looking to replace the nut at the "T." Thank you.
Old Nov 6, 2009 | 03:51 PM
dirtydog's Avatar
dirtydog
Moderate User
did you strip it or are your tools very selective?
Once you open up that line, you'll need to bleed the entire system.
Old Nov 6, 2009 | 07:48 PM
LChavez's Avatar
LChavez
Just leaking at the nut. Bleeding the system is not an issue. Its an 03 ram 1500 4.7l v8.
Old Nov 6, 2009 | 08:07 PM
dirtydog's Avatar
dirtydog
Moderate User
I just went out and checked. looks like 12mm for the hardlines out the sides and a 14mm(tight fit) for the top fitting/rubber line.
Old Nov 7, 2009 | 11:48 AM
LChavez's Avatar
LChavez
Thanks a ton!!
Old Nov 7, 2009 | 01:26 PM
dirtydog's Avatar
dirtydog
Moderate User
No problem. I had nothing else better to do.
