3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I didn't check anywhere to see how much it would cost or the hours it would take.
It took me 3.5 hours to change myself after a freind disconnected the a/c and I'm a carpenter!
drop the steering column, pull every panel with a switch, button or lever. pull the glovebox, ashtray, cupholder and panel directly behind windsheild. Then you take out approx 4 bolts form each side, 4@ the wind sheild an 2@ the center hump. Unhook a/c and heater lines,4 or 5 bolts holding heater box ( 2 bolts in engine compartment). Take heaterbox out passenger side and there is your heater core.
Yeah its a pain in the A!
I figured it was from all I've read about doing it on these trucks. All you can do is keep you flushing and refilling your coolant at recommended intervals and hope it doesn't crap out on you.
