fuel pump power
Old Nov 9, 2009 | 01:32 PM
highline9's Avatar
highline9
Default fuel pump power
Real quick, hopefully someone can point me in the right direction...2002 Ram 1500, single cab V6 3.7L, red in case you were wondering...Parked the truck due to suspension problems...tried to start the truck after two weeks to keep the fluids moving...everything sounded fine, but no start...seemed lack of fuel...towed to shop, they told me fuel pump...Put in new fuel pump and relay, still no start, same symptoms...plugged in test light to relay port, got light...tried different relay ports, all same light sequence...port looks good...re-dropped tank, plugged test light into electrical connector that connects to the new fuel pump, no lights, thus i'm thinking no power at connector (4 wire connector)...FYI, I checked the 15 amp mini fuse and replaced for good measure...Any ideas?
Old Nov 9, 2009 | 04:05 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can give you this much to hopefully allow you to back track your wires
