Help wiring New driving lights
Old Nov 10, 2009 | 01:04 PM
aidenhardcore's Avatar
aidenhardcore
Default Help wiring New driving lights
So I'm ordering some nice 6in lights at this auto store today and going to be putting them behind my 07 ram grill. I did this wiring before on my jeep but forget alittle. As i think it goes, red wire goes from lights to battery, to power them up, then other red wire to switch to turn them on then black wires to ground. And somewhere in there, have a fuse. Does this sound right. Thanks.
Old Nov 10, 2009 | 01:11 PM
BadHab1t's Avatar
BadHab1t
battery to fuse to switch to lights ....black ground ....if no fuse youll burn em up.....
Old Nov 10, 2009 | 01:26 PM
kx250frider617's Avatar
kx250frider617
there is also a green turn on wire, just hook it straight to the battery or a 12v source. It is so the lights only turn on when the high beams are on but if you connect it to the battery you are able to turn the lights on whenever you want.
Old Nov 10, 2009 | 07:27 PM
MikeHTally's Avatar
MikeHTally
Battery to fuse to relay to lights. Low current side (also fused) to a switch mounted wherever you like.
