Power Steering and or rack & pinion how to tell?
Old Nov 18, 2009 | 07:43 AM
donahuej's Avatar
donahuej
Wink Power Steering and or rack & pinion how to tell?
Great site - I have used this forum many times - thank you. Question - yes I have used the hell out of the search button....here is the truck 04 Ram quad cab 4x4 hemi.....
How to tell if the PS pump is bad or the dreaded R&P? My symptoms sometimes hard to turn the wheel at a stand still, moving a trailer backing into my spot....etc...
Checked the fluid Good to go.
No puddles of fluid just the normal fittings begin dirty
No big leak and or fluid on the rack....
One other thing went I check the fluid the lid popped off, like it had built up pressure. I hope it's the pump.
Thanks for you time....
Old Nov 18, 2009 | 10:23 AM
V_Scapes's Avatar
V_Scapes
Ive replaced both racks and p/s pump in my 04. when you turn the wheel at anytime does it make a grinding noise? im no pro but i would guess its the pump. usually if its the rack it would be leaky and you might get vibrations on the highway.
Old Nov 18, 2009 | 11:12 AM
donahuej's Avatar
donahuej
No grinding - not wet near the rack...just hard to turn at a stop...
Old Nov 18, 2009 | 11:35 AM
jstmahoney's Avatar
jstmahoney
I'd Say the pump. Try replacing it.
Old Nov 18, 2009 | 11:49 AM
donahuej's Avatar
donahuej
Thanks will do...
Old Nov 18, 2009 | 07:06 PM
donahuej's Avatar
donahuej
Changed it - it was the pump - sounds like a different truck. I guess I didn't hear the original one going bad......I'm backin into every parking spot now!
Thanks!
