Fox shocks where to find? How to install?
Old Nov 19, 2009 | 04:12 PM
butch1581's Avatar
butch1581
Default Fox shocks where to find? How to install?
where do you get Fox shocks for a stock height truck? (06)
Also if I were to get shocks for the front end of my truck, I assume you compress the spring and remove the shock that is in there and replace it? The stock springs are still used correct? I have never repalced shocks that are inside of a spring before, and struts come as an assembly...thanks
Nothing on their site either:
http://www.foxracingshox.com/offroad
Old Nov 19, 2009 | 07:53 PM
98cherryram's Avatar
98cherryram
They dont even have any dodge options on that site at all... I think your best bet is to get the bilstein shocks, Ive never heard of anyone running fox shocks on a dodge, seen it on a lot of fords, and a couple of chevys...
Old Nov 19, 2009 | 08:17 PM
CreativeOffroad's Avatar
CreativeOffroad
You can definately run Fox shocks on our trucks, but just running them as replacements on a stock-height truck might be a waste of your money.. I'm sure you could find something else that will work well for alot cheaper.
Old Nov 19, 2009 | 10:22 PM
butch1581's Avatar
butch1581
you are probably right I just know how awesome their shocks are for quads, and I saw in the FAQ section that guys had the fox shocks. Probably will look into Bilstein.
If I get a set of fronts how do they install on my type of shock or strut or whatever those gay things are?
Old Nov 19, 2009 | 10:28 PM
hemiguy0302's Avatar
hemiguy0302
You need a spring compressor to pull the spring off of the struts (shocks) then it is just a matter of switching springs from shock to shock.
Old Nov 19, 2009 | 11:59 PM
butch1581's Avatar
butch1581
got it thanks man
